3000mah 3s LIHV full charge is 13.05V
battery life
Re: battery life
How long is the battery last?
I have about 4 cycles and I can not get more than 15-16 min.
Re: battery life
The Zino transmitter battery :18650 Li-ion 2600mAh.
Re: battery life
In what percentage is the Zino battery left when you land? Thank youme_fa036eEZef wrote: ↑Thu Jan 03, 2019 4:20 amHow long is the battery last?
Re: battery life
Al 20%.
La verdad es que no me están durando mucho todavía.
El otro día solo 13min pero es que hacía 4-5 grados y eso es malísimo.
Pero lo máximo que he sacado son unos 17.
Re: battery life
The batteries are LIVs at 4.35v / cell. The Hubsan charger charges at 4.30 / 4.32. I complete my load with a ULTIMATE PRO 10 charger up to 4.35 v with a perfect balance between the cells. I have made 92 flights to date, about 25 to 30 refills, the flight time at 20 ° is 23 minutes. At 4 ° it is between 17 and 19 minutes.
- IMG_2431.JPG (2.8 MiB) Viewed 11733 times
Re: battery life
hola, yo tengo B6AC 80W , ¿en que posición lo pones para cargar esa batería? ¿en lipo? ¿hay que tocar algún parámetro para que llegue a los 4,35v? ¿si es así me lo parias indicar? las lipos normales solo admiten 4,20v como máximo , ¿ese voltaje de 4,35v es el correcto para esa batería ?
un saludo y gracias
un saludo y gracias
Re: battery life
Controller battery.
- Screenshot_20190111-112018.png (2.23 MiB) Viewed 11683 times
Re: battery life
The Zino battery is a LiHV 3S 3000mah, max charge for each cell is 4.35V
The Imax B6 with firmware 1.13 will charge LiHV batteries as there is a setting for this battery type.
Re: battery life
No need to modify your charge cable just get this already made ballance extension for 5.97 + shipping at Amazon.
ProgressiveRC
3S JST-XH Charge & Balance Cable https://www.amazon.com/dp/B00UY2Q23I/ref=cm_sw_r_cp_apa_i_P6kpCbRPZE726
ProgressiveRC
- Screenshot_20190114-100040~2.png (230.78 KiB) Viewed 11670 times
