Zino Drifting Going Forward
dogstar7
Post by dogstar7 » Sat Jan 12, 2019 9:10 am
When going forward my Zino drifts anywhere from 5 to 10 degrees
I was thinking this was due to the controller paddle being inaccurate, but now I am encountering it any time I send my Zino away at a constant rate for more than 20 meters. Is anyone else seeing this? Someone else mentioned it on a FB page and others agreed this was happening
Gorillaman
Re: Zino Drifting Going Forward
Post by Gorillaman » Sat Jan 12, 2019 9:14 am
When you hover at altitude... does the video(Zino) yaw left ever so slowly?
kenman
Post by kenman » Sat Jan 12, 2019 10:25 am
mine does yaw left a little,I usually flip the stick,and it stops....would be good if we had a little bit of trim settings,or if I could just adjust my dead zone a a little larger
501Pete
Post by 501Pete » Sat Jan 12, 2019 7:59 pm
I initially thought that perhaps mine was doing similar.
That's until I looked at the screen and found I was applying aileron when I thought my stick was straight :o
I've got a better feel on it now and my stick extensions help enormously.
Half the problem I think is the stupidly small sticks, they make everything far too sensitive.
dogstar7
Post by dogstar7 » Sun Jan 13, 2019 1:01 am
Yeah, I really do not care for the game-style controller either. I hope Hubsan will one out with a better pro controller in the future.
akifoktar
Post by akifoktar » Sun Jan 13, 2019 4:52 am
My Zino does same. On my last video when going south it deviated to left, wher going north it deviated to right. So i was thinking it is a compass issue
fb_43b9ftbKWM
Post by fb_43b9ftbKWM » Sun Jan 13, 2019 6:50 am
I agree. If it's like you say, then it seems to be a compass issue. (as long as you mean coming "coming back" when you say "going north")
Gorillaman
Post by Gorillaman » Sun Jan 13, 2019 7:44 am
On a RTH flight, does the Zino come back on an angle? Not pointing at the Home point but off to the right about 20 degrees or so?
akifoktar
Post by akifoktar » Sun Jan 13, 2019 11:24 am
Yes moves deviated also on doing RTH
dogstar7
Post by dogstar7 » Sun Jan 13, 2019 2:12 pm
Still doing the toilet bowl after compass calibrations, too. Wondering if the magnetic shielding of the GSP module is adequate
