Zino latest Camera firmware-IT V0.3.3
ge_504b6aPsfA
Re: Zino latest Camera firmware-IT V0.3.3
Post by ge_504b6aPsfA » Fri Jan 11, 2019 3:01 pm
I thought the camera firmware was to be loaded to an SDcard...as in the Hubsan update videos.Are we on the same page here??
Post by 501Pete » Fri Jan 11, 2019 3:08 pm
Yes. Are you thinking of trying a different method we don't know about?
ge_504b6aPsfA
Post by ge_504b6aPsfA » Fri Jan 11, 2019 3:14 pm
To the sd card..but don't see any V0.3.3...I only see FC 46 one which is updated with the usb cord only.
fb_43b9ftbKWM
Post by fb_43b9ftbKWM » Fri Jan 11, 2019 3:35 pm
akifoktar wrote:
Fri Jan 11, 2019 2:34 pm
dogstar7 wrote:
Fri Jan 11, 2019 1:56 pm
I appreciate the effort individuals have taken to post information about work-arounds to open the invalid zip files. Going further and uploading the extracted files on the Google cloud is going above and beyond and certainly should be applauded
I'm frankly fed up with Hubsan technical support for yet another failure
For the life of me I cannot understand how you can release a file that you obviously didn't test as a download yourself
If anyone had simply tried to retrieve the file and install it themselves they would have caught this error before announcing the upgrade publicly
It is not a big issue. Different programs may give compatible issues. If developer use 7zip mostly it works on winrar but this may happen very rare
The "firmware.zip" that Hubsan uploaded to their Server today is in fact a RAR archive.
The 7-Zip software can decompress RAR archives, but it can not create or modify RAR archives. So the developer couldn't have used 7-Zip to make this file.
What could possibly have happened is that the develover did in fact make a regular RAR archive using WinRAR, but the person who is responsible for putting new firmware files on Hubsan's web server just simply renames anything he/she gets to "firmware.zip" in order to avoid having to change the website's code.
akifoktar
Post by akifoktar » Fri Jan 11, 2019 3:40 pm
You are right. After i change file type as rar. Winrar could see all files. Solution is developer should compress next ones as zip file. not rar file.
Jlat
Post by Jlat » Fri Jan 11, 2019 4:23 pm
7zip did the trick! Updated and appears to be good. Took a quick test flight to check soft focus issue but only had it up for a couple minutes before it started sprinkling;-/ Unfortunately weather here won't clear up till Sunday but will try to get some video then. Good Luck!
DonHeintz
Post by DonHeintz » Fri Jan 11, 2019 4:26 pm
The changing of the file extension to rar didn't work for me but if I right clicked the file and chose extract files with WinRAR then it extracted the files. But the only files I got was the v46 firmware and the install tool. No camera firmware.
I found a link on another Zino subject and it gave me this link https://drive.google.com/drive/folders/1d6-YEYmefBRgK2EByHn1561TNC2DFHeF
This worked to get the camera firmware but I couldn't download the files using Microsoft Edge and had to switch to Chrome to download it.
ge_504b6aPsfA
Post by ge_504b6aPsfA » Fri Jan 11, 2019 4:43 pm
You are right..they should have used Zip file
3108vibhash
Post by 3108vibhash » Fri Jan 11, 2019 6:35 pm
So the soft focus and pink flashes issue still persists?
dogstar7
Post by dogstar7 » Fri Jan 11, 2019 6:58 pm
Problem solved (edited)
