Zino latest Camera firmware-IT V0.3.3
Leducn
Re: Zino latest Camera firmware-IT V0.3.3
Post by Leducn » Fri Jan 11, 2019 1:39 pm
I have a question, why do we have 2 files for every videos the we take? Different size .
Leducn
Post by Leducn » Fri Jan 11, 2019 1:45 pm
501Pete wrote:
Fri Jan 11, 2019 1:01 pm
Here.
For those of you unable to extract the zip file, I've added the files to Google drive.
https://drive.google.com/drive/folders/1d6-YEYmefBRgK2EByHn1561TNC2DFHeF?usp=sharing
The Md5 Hash is
3edb29f55c77c3af49f5a4470b0c43ba20190111
if you need to confirm.
Thank
ge_504b6aPsfA
Post by ge_504b6aPsfA » Fri Jan 11, 2019 1:47 pm
I agree..there is no VO.3.3 camera firmware to be copied to your sd card to update :?:
kenman
Post by kenman » Fri Jan 11, 2019 1:50 pm
thanks for the download, I to couldnt open the file....win rar opened it, but as others have said, their was nothing but the 46 FC file!!!
Thanks Again!!!
dogstar7
Post by dogstar7 » Fri Jan 11, 2019 1:56 pm
Problem solved (edited)
fb_43b9ftbKWM
Post by fb_43b9ftbKWM » Fri Jan 11, 2019 2:02 pm
501Pete wrote:
Fri Jan 11, 2019 1:19 pm
Misi3k wrote:
Fri Jan 11, 2019 11:29 am
Take couple of photos so we can see if the quality (and size) is improved
I'd say there is no change in the photos. They are all between about 800KB ro around 1.2MB.
I have no older ones to compare with, as I don't take photos, and the ones that I did previously were all binned ;)
Here's a couple anyway.
Please note these were taken late in the day, it is very overcast and the light levels are low.
Settings were all on Auto exposure so the ISO is obviously pretty high too.
White balance was set to Cloudy, which gives a bit more Chromiance than normal.
Frame captures are still a much better option IMO
I see little if any difference in video.
I'll post up some later on.
I for myself am most interested in knowing whether Hubsan have been able to fix that so-called "pink flashes" problem.
The previous publicly released camera firmware version was V0.2.1. Now we are at V0.3.3. I wonder if there were more changes made in between these versions than just "Improved the video quality".
SkillPig
Post by SkillPig » Fri Jan 11, 2019 2:07 pm
Noone has answered the most important question. Have we seen the end of the soft focus issues?
akifoktar
Post by akifoktar » Fri Jan 11, 2019 2:34 pm
I appreciate the effort individuals have taken to post information about work-arounds to open the invalid zip files. Going further and uploading the extracted files on the Google cloud is going above and beyond and certainly should be applauded
I'm frankly fed up with Hubsan technical support for yet another failure
For the life of me I cannot understand how you can release a file that you obviously didn't test as a download yourself
If anyone had simply tried to retrieve the file and install it themselves they would have caught this error before announcing the upgrade publicly
It is not a big issue. Different programs may give compatible issues. If developer use 7zip mostly it works on winrar but this may happen very rare
Post by 501Pete » Fri Jan 11, 2019 2:37 pm
I saw zero pink flashes today over almost an hour of flying.
That means very little however, as I've only ever seen it momentarily, in fact 3 times in 47 videos. :)
Post by 501Pete » Fri Jan 11, 2019 2:42 pm
Very true.
Not all Zip files are equal.
Having a whinge because the developer didn't use the zipper that you normally use, isn't really their issue.
I had no issues, unzipping it once I realised it was probably not a native Windoze zip (not everyone uses Windoze).
Others who use Mac IOS unpacked it without issue too.
So like any end user, it is up to you to pick a compatible tool to do the job :D
