Disappointed Zino Picture Quality-Zino latest IT firmware will solved this issue
3108vibhash
Re: Disappointed Zino Picture Quality
Post by 3108vibhash » Thu Jan 03, 2019 8:14 pm
Saw this video. Clearly zino video has soft focus, osmo pocket had good focus. However, I can see jello effect on osmo pocket.
Post by Hubsan-Ailsa » Fri Jan 04, 2019 1:48 am
Hello all ,
The latest IT firmware will solve this picture issue.,which will release on the Hubsan official website soon.
Misi3k
Re: Disappointed Zino Picture Quality-Zino latest IT firmware will solved this issue
Post by Misi3k » Fri Jan 04, 2019 4:51 am
What do you mean by 'IT firmware'?
josdoss
Post by josdoss » Fri Jan 04, 2019 4:56 am
IT
Information Technology :D
akifoktar
Post by akifoktar » Fri Jan 04, 2019 5:13 am
Hello all ,
Thanks hubsan, nice to know you are improving
Post by Hubsan-Ailsa » Fri Jan 04, 2019 7:21 am
Hello all,
Image transmission firmware will solve this picture issue.thanks
me_075d7ydEYr
Post by me_075d7ydEYr » Fri Jan 04, 2019 2:12 pm
I don't think the Zino camera even has any focusing capabilities, it's just set to infinity focus as most action cameras are. Also it would look as if the "still" mode of the camera merely captures a video frame, the resolution is exactly the same and there's no EXIF data in the file at all. Thus, fiddling with compression settings would bring very little additional benefit.
The worst problem seems to be the white balance, it's really visibly changing when the scene is changing, it's like a flick of a switch. Also there is some relatively aggressive noise reduction going on, in darker scenes there are some visible artifacts stemming from this (streaks, motion blur).
me_075d7ydEYr
Post by me_075d7ydEYr » Sat Jan 05, 2019 11:11 am
Please see attached file, such streaks are easily visible when panning for instance. This is from a tree branch. When ascending from behind some trees, the whole forest leaves a noticeable blur against the sky.
Streaks from the camera whilst panning
akifoktar
Post by akifoktar » Sat Jan 05, 2019 12:34 pm
Hello all ,
Latest IT firmware update will solve video softness? or only picture compession?
Magnum1956PMQ
Post by Magnum1956PMQ » Sat Jan 05, 2019 12:42 pm
Like all drones, even DJI, automatic modes are not the best. It is necessary to make manual adjustments ... White balance to manually adjust following cloud or sun, ISO at 200 fixed if sun and at 400 if clouds. The videos are then correct and the pink or blue images of the quick change of exposure no longer exist. You must also have a card SD ev V30 A2 minimum! . For photos, it's something else. The compression seems too strong, Hubsan will perhaps reduce it. My photo sizes range from 650 KB to 1.8 MB.
La photo en l'air fait 894 ko
La photo dans le parc fait 1,7 Mo
