This last update was good on everything but my camera...it now records with a dark Blue/Green overlay on photo/video on 2 out of my last three videos. My question is can I reinstall just the camera firmware update for 1.0.44 when the camera was working perfectly or do I have to install the whole 1.0.44 firmware with it?
Rollback Firmware?
- ge_8efac33d06
Re: Rollback Firmware?
Did you try resetting the video settings on the App? It seems like you lost the red component of the RGB data. Could also be hardware related ... loose camera cable perhaps.
Took video at home and it was fine in 1080p and 4K???
- ge_8efac33d06
Does your FPV show the same blue green overlay? Also, suggest you look at the low resolution version and see if you have the same problem.
Hello irussphone ,
Would you mind to provide the picture of the Zino firmware version in the APP for our reference?
Did you update the FC 1.0.46 , gimbal firmware and Zino IT V0.2.1.vb25 together?
