Hubsan - Ailsa Suggest for next firmware update
Can we get a manual setting for the RTH height, or at the very least have the RTH height raised to 30 metres. 10 metres does not clear the trees around here.
Re: Hubsan - Ailsa Suggest for next firmware update
If it's going to be changed make it user selectable.
10m is fine.
I would not feel at all comfortable raising it to 30m by default.
10m is fine.
Imperial settings would be nice for USA who are not used to Metric units.
Hello peterkng ,
The Zino should be at least 10 meters far from the transmitter when you active the RTH. You can active the RTH in 30 meters distance and height
Customer will have more option for their preference RTH distance in this condition
I am not worried if I activate it as I will set the RTH I want, it is when it does an auto return such as low battery or loss of signal due to phone app crashing is when there is an issue.Hubsan-Ailsa wrote: ↑Thu Jan 03, 2019 7:58 amHello peterkng ,
