Battery issue
me_35a75xUiXe
Battery issue
Post by me_35a75xUiXe » Wed Jan 02, 2019 3:27 pm
I just received my hubsan zino charged the battery and get about 16 minutes maximum flight time in normal mode. That is flying tell the zino begins to return home. Ive tried this a few times since same flight time. I am also not flying aggressively or in strong winds
I checked the battery cell voltages which appear 4.31v,4.31v,4.35v.
What i found strange was the resistance across the cells was different .
Two cells were around 60Mohms and the other cell 6Mohms.
Is this correct? Do i have something wrong with this battery?
Shouldnt i be getting more flight time?
Fritzz
Re: Battery issue
Post by Fritzz » Wed Jan 02, 2019 4:59 pm
which outdoor temperature do you have?
in winter it's normal
me_35a75xUiXe
Re: Battery issue
Post by me_35a75xUiXe » Wed Jan 02, 2019 5:00 pm
I live in australia its not winter here its summer
35 degrees celcius
Re: Battery issue
Post by 501Pete » Wed Jan 02, 2019 5:27 pm
I currently only have one battery (awaiting delivery of more).
Yes the IR on mine is quite shocking, 118mΩ (luckily no MΩ :o ).
I was hoping this was a one off, but as with previous Hubsan batteries, I guess it's par for the course :cry:
You'rs is worse. With a total IR of 126mΩ, that is going to seriously eat into usable capacity.
Saying that, I can get 20 minutes flight time.
If the next batteries I receive are no better, I'll end up using stock Lipos and change out to XT60 connectors.
Djose24
Re: Battery issue
Post by Djose24 » Wed Jan 02, 2019 5:59 pm
me since I received it only 17 minutes ago. All flights have been windless always at a temperature of 17 degrees Celsius. Of 15 battery charges, twice was at 80% instead of 100%. Hubsan could make a decent charger and charge 2 batteries, because the zino with 1 battery does not test almost the functions it brings and that I have android with the hubsan app very limited.
me_35a75xUiXe
Re: Battery issue
Post by me_35a75xUiXe » Wed Jan 02, 2019 10:26 pm
I was thinking of ordering second battery but is it going to be hit and miss interms of quality. Will i get a better battery?
Djose24
Re: Battery issue
Post by Djose24 » Wed Jan 02, 2019 10:47 pm
I have the same question, and I would like for a drone of these characteristics should carry two batteries and a good charger for them. Hopefully they have understood us and take something for it.
