I think that too and besides the building quality of my lens cover is not the best! Today I had a closer look at the glass cover and I found some small chipping in the glass. It is also not very well aligned as you can see on the markings. Who else have that problem?Bellerophon wrote: ↑Sat Dec 29, 2018 7:09 pmI suspect it may be a hardware issue for those affected.
Pink & Yellow Flashes in recorded video
Re: Pink & Yellow Flashes in recorded video
- B133EAFB-B6B8-467F-A20D-6B7300F7D70F.png (1.53 MiB) Viewed 10920 times
- 783CEFF0-4944-4384-ACA2-55EC479AB732.jpeg (188.14 KiB) Viewed 10920 times
You know that's not the lens right? That is just a protective cover over the front of the camera.
The lens is the circle around the bluey coloured dot.
- IMG_1312.JPG (29.41 KiB) Viewed 10908 times
JanisHemmer wrote: ↑Sun Dec 30, 2018 6:28 amI know that’s not the lens.... Just corrected it
By the way - in Germany some words have the same meaning![]()
Hubsan-Ailsa any news on this?
Same problem for me, i see no hubsan reaction, i will send back the zino because it makes it unusable
Need a better firmware .HUBSAN DO IT RIGHT.
I have updated to the Firmware V1.0.46 and flew it today with the temperatures in the low 40 Deg F temperatures. I think this may be the lowest temps I have flown in and I got the pink flashes in my videos. Never had that before. Will try again in a couple of days when it warms up to see if that changes anything. The actual drone handled very well like it did before all of the previous updates.
Pink flashes are not hardware issue. İt is image process issue and can be fixed by update. Dont worry i m sure hubsan will fix it.
