Gimbal protection error - Zino 0x0004 - Warranty Service - Shipped back to Hubsan USA Office
peterkng
Re: Gimbal protection error - Zino 0x0004 - Warranty Service
Post by peterkng » Sun Dec 30, 2018 7:20 pm
I’ve tried the fix behind the gimbal as previous stated and could not locate a button and was worried of messing it up even more. We need a fix ASAP this is ridiculous.
The fix is the reset button :?:
zinofan
Post by zinofan » Sun Dec 30, 2018 7:45 pm
Does not work at all. :?
peterkng
Post by peterkng » Sun Dec 30, 2018 7:49 pm
If done correctly and it did not fix it then it is probably a hardware issue i.e broken. :(
ge_38d322Tv8y
Post by ge_38d322Tv8y » Sun Dec 30, 2018 9:16 pm
Looks like you have to lift up the ribbon to get access to the button?
ge_38d322Tv8y
Post by ge_38d322Tv8y » Sun Dec 30, 2018 11:12 pm
So took off the cover behind the gimbal and disconnected the fpc connector that is super tiny tried the best I could to retach and powered on with same issue. I left the power on with my camera display and gently pushed the fpc connector around until it stopped moving. I rechecked the gimbal response and it reacted immediately and is good as new. The new test will be in flight tomorrow to see if the connection stays.
It’s definitely not a button you push but more of a fpc connecting just like changing out a screen on a phone where the ribbons attach.
This is definitely where Hubsand needs to start it appears the connection is coming loose.
zinofan
Post by zinofan » Mon Dec 31, 2018 8:02 am
Bingo
fb_43b9ftbKWM
Post by fb_43b9ftbKWM » Mon Dec 31, 2018 8:37 am
So, after all there is no "reset button" on the Zino's gimbal?
The place you are supposed to push on is basically the backside of a connector of a flex flat cable that in some cases has slipped out of its socket and needs to be pushed/locked in place again?
zinofan
Post by zinofan » Mon Dec 31, 2018 8:48 am
Thats how I see it.
ge_38d322Tv8y
Post by ge_38d322Tv8y » Mon Dec 31, 2018 10:36 am
Yep exactly
zinofan
Post by zinofan » Mon Dec 31, 2018 11:53 am
Yep exactly
Ailsa emailed asking for a video. I sent a video. I am hoping for a simple replacement.
