Disappointed Zino Picture Quality-Zino latest IT firmware will solved this issue
Re: Disappointed Zino Picture Quality
Apparently, not every Zino has the problem of blurring, or some have due to even lower quality of toy drones not as high expectations as we?!?
But just because of the technical data, the cam should "take better pictures".
So far everyone has very low size images around 1 mb or less. I have not seen any picture which is really good. Hopefully hubsan will be able to optimize the quality, so far they have been very helpful in improving the drone.
To all Zino owners here in the forum, please also post your Zino pictures, because I suspect that possibly a part of the camera lenses makes problems.
A Picture 3840 x 2160 direct from Zino
Zino compressed it to 950kB - there is not much left.
Video ist a LITTLE sharper than a picture.
Guys you know the Zino is not like a DSLR or other still camera? It only takes a frame grab from the video stream off a small video CMOS it is not a full frame CMOS like in a still camera. If you don't like the inbuilt compression use an external capture application.
This is a frame cap from a 2k video I recorded using an external player. It was 967K with 90% quality compression using Media Player Classic.
- 20181228_142727_0010_AA.MP4_snapshot_00.43_[2018.12.28_16.17.33].jpg (967.56 KiB) Viewed 10570 times
Congratulations Peterkng, YOU got a Zino with a good lens!
Please show us a JPG (made by Zino itself) from the same area.
There are TWO "problems" focus AND Compression.
My intention is not to make Zino bad. I want to give Zino the opportunity to improve their properties. All sorts of opportunities have not yet been created for Zino. Anything else can not matter.
bye Fritzz
bye Fritzz
I usully like to take picture using picture button given on drone to take still photos and not capture from video. Hopefully, that compression issue will be fixed.
