Hey everyone
Feel free to post here your distances reached with the Zino with details if you had obstacles, issues with the connection etc.
My maximum was today with 682,8m from the transmitter, then it lost signal and automatically returned to recover it. I don't find this dissapointing because I was controlling the drone almost under some high-voltage electricity cables, so I need to try again somewhere else.
Range of the Zino
Re: Range of the Zino
1300m, straight up with no loss of siganl. roughly 900m horizontal so far. i reckon it will go to about 2 miles?
1300m straight up? 500m is the maximum. How did you do this?
2 miles = over 3200 meters, you must be dreamingme_3894dpwLeC wrote: ↑Tue Dec 25, 2018 2:22 pm1300m, straight up with no loss of siganl. roughly 900m horizontal so far. i reckon it will go to about 2 miles?
Hello, today I was the day that farther I took it, 120 meters high and about 900 meters away without any signal problems like lag and others. Also the flight area is free of obstacles, high tension towers, mobile antennas, trees, etc.
I've been to 930m out when it lost signal and RTH. This was over a mixed neighborhood and over a busy intersection. About 350m high before RTH same area.
I do not like to take it more than 6-700m out as it just isn't really stable. The app will freeze for a brief second and go in and out. There's bound to be interference here, but also a lot of farmland as well.
Hello all
Thanks for your support of Hubsan Zino
Zino Transmission Distance: 1KM
