The iOS app for my zino doesn’t want to connect to WiFI, I can’t press the ‘Set transmitter and aircraft connection’ button. Do you know whether this is a bug or I am doing something wrong
Thanks.
Hubsan IOS App Not Connecting
Re: Hubsan IOS App Not Connecting
Cell not connected to transmitter. Unplug the cord and then reconnect.
You DO NOT connect to the WiFi. That's the quad "talking"to the remote. YOU use OTG cable to connect phone to remote.
Unfortunately,Hubsan did not make that clear.
Be patient,it may take several attempts for it to"pair".
Thanks, I found out that the corrrect procedure is to turn on the controller, plug the USB into the phone (Android), then start the drone and wait for it to pair. The new problem that I have
is that 'GPS Lock' comes up in the top right corner just after auto-takeoff and I can't control the drone with the controller. Have I pressed something, or is this an issue for support? (The drone doesn't fly away or anything, it just hovers there.)
