Got it.
Zino battery Indicator
Re: Zino battery Indicator
This is a LIHV(lithium ion high voltage)battery that should be charged on a balance charger that will charge them. As normal lipo batteries charge to 4.2v per cell,lihv charges to 4.35v per cell. Unless you are charging it on a balance charger(after making your own cord) it is not ever fully charged.
So the balance charger which came with Zino is not charging it completely..hmmMrDronenut wrote: ↑Sun Dec 16, 2018 11:29 pmThis is a LIHV(lithium ion high voltage)battery that should be charged on a balance charger that will charge them. As normal lipo batteries charge to 4.2v per cell,lihv charges to 4.35v per cell. Unless you are charging it on a balance charger(after making your own cord) it is not ever fully charged.
Hello 3108vibhash ,
Would you mind to try to test the battery by the Volt meter when it full charged?
