Flights with original software/firmware
mab961
Post by mab961 » Mon Dec 17, 2018 1:41 am
My first flights were very good control wise. Quite a bit of drifting compared to my H501S.
My second flights were nerve-wracking. The Zino lost contact with my controller and auto-returned home. My distance out was 70m and about 30m high. I tried six more flights on two batteries. All flights lost contact with my controller and [luckily] successfully auto-returned home. All the subsequent flights were less than 70m away and 10-25m high. I always had 12-15 satellites. My Zino and controller batteries were fine. Since I had loss of signal I was unable to close my videos. After each returned flight, I went thru all the setup/configuration and each take off was normal
I was going to DL the updates, but did not see them on the https://www.hubsan.com/na/index.php?main_page=support page, as the video indicated.
After reading some of the comments of others who had done the updates, I'm kinda concerned about that now too. Has anyone else had loss of signal in close range like I have?
Thanks,
Mark B.
Texas, USA
Re: Flights with original software/firmware
Post by Hubsan-Ailsa » Mon Dec 17, 2018 2:32 am
Hello mab961 ,
Would you mind to try to update the Zino firmware to the latest one?
FC V1.0.44
