Dear Hubsan Zino Fans,
The Zino requires for the 32-128GB SD card with U1 or above.Kindly suggest using sandisk,kingston and samsung SD card .
Zino SD card?
Re: Zino SD card?
Is that a regular size SD card or micro?
Re: Zino SD card?
I have a Sandisk 128GB U3.
I put the two files on it, put it in the aircraft with the contacts side up. Then put the battery in and turned the aircraft on. The red led stays lit and does not flash. Help!!!
Re: Zino SD card?
I had the same problem and this is how I had to do. The first file was the SD card install file, you have to open it up and see two files that you copy to your SD card, but I deleted the SD card install file from the card before I installed the two files it contained.
The Zino will not open file folders just files.
So you copy a total of three files to your SD card. Then put it back in the Zino and turn it on, you should see the red light blinking. Just wait for it to stop.
Mine stayed on after it finished installing.
Then turn it off and remove the sd card.
Then turn it back on without the SD card and connect with controller and phone so you can check firmware versions did change.
Before you reinstall the SD card use your computer to delete the three files that you used to update or it will keep updating.
Hope this helps.
Hope this helps.
Re: Zino SD card?
The tutorial doesn’t mention it but you have to format the SD card before adding the firmware files and updating. I’m all set now.
