Hello Karakastibor ,
I email you a firmware to update soon.Hope will help you solve this issue.
Gimbal status ERROR0X80
Re: Gimbal status ERROR0X80
Do you send me that email?
Dear Ailsa,
I sent this letter to Hubsan.
I received the Zino on 05. December 2018.
I used this drone 4 days. I refreshed the Zino and after the software update this drone is unusable.
I gave a signal to the Hubsan inside of seven days on 11. December 2018.
I made everything what you advocated but the Zino is not working. I also sent video about the problem.
Nothing changes and the time is advancing.
This is not correct business approach.
I would like to receive your confirm in email that you exchange my Zino or you pay my money back.
If it does not happen in 2 days I will get in touch with the European Consumer Centres.
I would like to call attention of the Hubsan to observe the law.
My order number is 2523.
I hope to receive a prompt reply.
Tibor Karakas
Tibor Karakas
Hello Karakastibor,
Sorry for my late reply
Would you mind to try to press this part as attached picture to check if it can work normally?
Or kindly slide the pitch roller to check if it install tightly.
Waiting for your feedback
- Attachments
- 0X80 press gimbal.jpg (26.21 KiB) Viewed 8009 times
check your junk folder in your e-mail files
The pilot is the obstacle avoidance feature
Same problem here you hubsan somehow messed the gimbal with the update.
Still no solution to the problem too.
Hello fb_5baa4n9yHx,
would you mind to tell us your order numebr?I will email you
Try this - sorry for poor quality
