maybe the videos should not stop
me_24733Rj73H
Post by me_24733Rj73H » Tue Dec 11, 2018 5:02 pm
what do you think? come from a mjx bugs 5w and when I recorded on sd, the video was intact from start to finish. why on the zino it should not be so? :?: :?: :?: :? :?
Re: maybe the videos should not stop
Post by Hubsan-Ailsa » Tue Dec 11, 2018 8:23 pm
Hello me_24733Rj73H ,
Would you mind to share the videos which record by Zino for our better checking?Hope will provide right solution and help you enjoy better flight.
me_24733Rj73H
Post by me_24733Rj73H » Wed Dec 12, 2018 1:34 am
.the video images say nothing
..in the sd card I have so many pieces of video, it stops when the video signal loses, and starts recording again when the signal returns. Sometimes for some strange reason, it loses the signal even 20m away from me, and the video file is cut
Post by Hubsan-Ailsa » Wed Dec 12, 2018 3:16 am
Hello me_24733Rj73H,
According to your description,If the video signal loses then start again.It must be interfered by the local environment.
me_24733Rj73H
Post by me_24733Rj73H » Wed Dec 12, 2018 4:06 am
ok I agree that the signal is lost depending on the surrounding environment ... BUT the video should not stop, but continue to record, which with the zino is not so
Post by Hubsan-Ailsa » Wed Dec 12, 2018 7:21 am
I have feedbacked your issue to our engineer.Yes, recording will not effected by the signal lost.
For your issue ,would you mind to provide the video you recording for our better checking?Hope will solve this issue.
me_24733Rj73H
Post by me_24733Rj73H » Wed Dec 12, 2018 11:09 am
as you can see these 3 videos have been made in sequence, but there are no pieces in which the zino had lost the signal, and I was also very close to the radio control as can be seen from the first video.
irussphone
SD Card Fast Enough?
Post by irussphone » Wed Dec 12, 2018 12:18 pm
Do you have a "U3" level SD Card. That's the only other thing I can think of that might be affecting your recordings.
Here is the one I use:
https://www.amazon.com/gp/product/B06XWZWYVP/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
me_24733Rj73H
Post by me_24733Rj73H » Wed Dec 12, 2018 1:52 pm
ok I'll do a test and I'll let you know
