Upgrade Issue
Re: Upgrade Issue
Hello 3108vibhash,
If you still fail to work,would you mind to provide the video for demonstrate the issue that the gimbal can't move on and up?attached the firmware you update together.Thanks
Re: Upgrade Issue
Yes upgraded all including firmware. Remote transmission upgrade was not present in the folder.
Re: Upgrade Issue
Hello 3108vibhash,
Sorry for there have no change for the transmitter firmware.
Still waiting for your video for demonstrating the issue that the gimbal can't move on and up.
Re: Upgrade Issue
As replied before, that I was able to fix it. Still at low height it was not stable so will be checking it again and let you know. thanks so much.3108vibhash wrote: ↑Mon Dec 10, 2018 11:40 amWas able to fix it. Updated everything again. Aapparently there are two file in the gimble folder HY010 and Zino_G. In the video tutorial they selected Hy010 which I did early, this time selected Zino_G and gimble started working. Reset the gyroscope, calibrated again and working fine. However still at low height was revoling in circle by itself.
Re: Upgrade Issue
I come back from 2 flights with 2 batteries after updating the FIRMWARE.
Many problems have been solved, the ZINO is a little softer to drive, it is more stable and the camera control wheel is more progressive, with a slight inertia.
I used all modes of smart flights, except 2 that are not operational (in creative video: "Fly to the sky" and "Photography in orbit"), all other modes work correctly (on IOS). The target tracking mode works well too, but it is limited to 15m distance, which is short!
The button to review his videos or photos is still not active.
The settings of "feel" operations "virtual joysticks are not accessible connected device, we can not see the virtual joysticks either.
Everything else works and well.
Vidéo tomorrow ....
Re: Upgrade Issue
Voir ici dans le forum:
https://forum.hubsan.com/viewtopic.php?f=13&t=1157
Re: Upgrade Issue
Hello Magnum1956PMQ ,
In order to enjoy the clearly track mode ,so we set the distance limit.
While for the issue that feel" operations "virtual joysticks are not accessible connected device, if the Zino connected with the transmitter.The virtual joysticks will not work.if just connect with Phone ,the virtual joysticks will work
Re: Upgrade Issue
I got my zino at 9.dezember 2018 with same poblem.after update firmware and App the same problem.!,!!!
In the meantime i cannot calibrate the gyro and I hope, hubsan will send me a new drone.I will send it back, when i get a answer of my Mail.
I live in germany and i hope, you understand my english!
Re: Upgrade Issue
Ok, c'est noté ! Merci AilsaHubsan-Ailsa wrote: ↑Wed Dec 12, 2018 8:06 amHello Magnum1956PMQ ,
Re: Upgrade Issue
Hello speedfried ,
Would you mind to provide the video for demonstrating the Zino gimbal issue for us?Hope will help you analysis where is the issue.
