Case for Zino
Case for Zino
Anybody got suggestions re case for keeping Zino in!
Re: Case for Zino
I recently purchased a Lowepro BP200 on sale at Fry's. High quality, nice compact size with room for everything. It was made for Mavic drones so it works quite well for a Zino.
Re: Case for Zino
In Dustin Dunnill's latest video he had a bag from DJI for the Mavic that he seemed happy with.
Re: Case for Zino
https://www.banggood.com/Waterproof-Hardshell-Beatles-Backpack-Bag-Carrying-Storage-Case-Box-for-for-DJI-MAVIC-Air-RC-Drone-p-1278294.html?p=Y52605598373201405SQ&ID=533765&cur_warehouse=CN
Re: Case for Zino
Have you tried it yourself? You know that is for a Mavic Air and that is much smaller than the Zino. The space for the drone would need to be cut out quite a bit in my opinion, so much so that you wouldn't be able to use the foam insert cutouts for the other accessories.
Even the Mavic Pro stuff won't fit right since the Zino is just a little bit wider and taller. At least in the products with foam cutouts.
Re: Case for Zino
I thought you could use the Mavic Pro case if you could trim the foam insert. RC Saylor's said it was wider than the Mavic.
Re: Case for Zino
Just bought this backpack which is normally for the new Mavic 2. With some small modifications the ZINO should fit
https://www.wish.com/share/6735bjmuef
