It's Here It's Here
It's Here It's Here
I just got mine today in the USA. Got scared at first because the cardboard box said Zino A but the 4K Zino was inside. Charging the battery and remote presently and then we will see what I got.
- Attachments
- 20181203_154250_resized.jpg (254.87 KiB) Viewed 7939 times
- 20181203_154306_resized.jpg (119.23 KiB) Viewed 7939 times
- 20181203_154316r_resized.jpg (121.01 KiB) Viewed 7939 times
Re: It's Here It's Here
Did you order an extra battery? Did it come with it?
J'ai commandé une batterie supplémentaire sur ma commande d'origine, mais la seconde batterie est arrivée après.
It came with a battery but I ordered a second one on 11/1 but still showing as processing.
It came with the props installed and a second set in the box. Came with three adapters for your phone. A micro usb, a micro usb - C and one for an iPhone. Charger for battery and a USB cord to use your computer or phone charger to charge the controller. Everything you need to fly it right away. I have a droid phone so waiting for the batteries to charge before I can tell if there are any issues with the droid app.
Well everything is all charged and I turned it on and bound the controller and went thru most of the app. Unfortunately it is raining now and will be below freezing for the next week so I won't be able to fly it. I tried to take off inside but not enough room to see other it going up and then down. It appears that there is a button to choose the video format but when I tried it it said I needed an update. But it was showing on my phone so the video works. See Pics.
- Attachments
- 20181203_185007r.jpg (73.71 KiB) Viewed 7884 times
- 20181203_190319r.jpg (31.23 KiB) Viewed 7884 times
Since I couldn't take it outside I tried it indoors which didn't work out. I didn't have enough GPS signals so it drifted. At that point I didn't see any drift adjustment that other drones have on their controllers. I guess it depends on the GPS to hold it in place.Also It appeared that there is no way to move the camera side to side unless you turn the Zino. There is only one wheel on the controller that moves the camera up and down.
- irussphone
Got mine too Don...got it bound just with charge in the battery when it arrived. I had to take off my phone case to get the cable to connect though. I tried to change video resolution and it said it needed an update as someone else reported. Don't understand that as I got the latest iPhone update a few days ago???
I thought the resolution was only with the android phones but I guess it is and equal opportunity problem. Lol I also noted that using my laptop to charge the controller it seemed like it wasn't ever going to complete with the last light still blinking. But when I connected it to my phone charger it immediately finished with the last light going solid.
Knowing how Hubsan has improved other drones,
surely they will send us an firmware update for the Zino and improve the APP.
Well the weather is nice here in the south, I'll be flying soon
Phantom 3 Standard, Phantom 4 Pro, Mavic Pro, Hubsan X4 Storm, ZINO (One day
