Dear Hubsan Fans,
1000 Zino have been sold out.The USD$50 discount will not avalible on Nov 1
- Attachments
- have been sold out.jpg (467.13 KiB) Viewed 4387 times
Re: 1000 Zino have been sold out
Quick question, how many motors does the gimbal have? From what I saw in your advertising, the gimbal moves like it has only 2-axes. Is the third for panning left and right inside the drone? And is that controlled through the app or with the gimbal wheel on the side (where it can be switched from one axis to the other in the app)?
Thanks for any information.
Eric
Eric
You do not control roll and pan motors. Those are for stabilizing camera. You control only pitch (tilt) motor. If you need to pan - you perform yaw with a drone. And pan motor in the gimbal smothes pan movement.
Hello Eric,
The Zino is 3-axis gimbal.It is controller by the HT016B.
