Hi.
I had to change the control board of the h261a since one of the engines stopped working, but the engines are fine. I ordered a new control board and replaced it with the old one, this new board constantly detects low battery but it is well charged, it also does not pick up gps and does not ask for any type of calibration of the compass like the old plate. I have 2 new plates with the same problem.
If someone can help me I would be so thankful.
Thanks in advance
Problem control board h216A
Re: Problem control board h216A
Hi,
I also having same issue, I was replaced the new flight control board but the application alway showing "Low Battery". It's so weird I was bought 2 plates of flight control but still showing same issue.
I hope Hubsan can advise for the solution.
Thanks,
Iyunk
Thanks,
Iyunk
Hi, not sure if this is control board or not, but my h216 desire starts with 11 sats on gps and a few minute into flight sats show n/s. then back to 11 for a few seconds then n/s etc etc. why do satilites not lock on?? any ideas? thanks eamon
I had the same issue, when i connected show´s low battery and no GPS signal, and the control board is new and original from hubsan.
Any help with that huban????
my H216A was delivered in October 2018 and I have a similar problem
(says 0% battery, one prop spins really slowly all the time, one prop spins really fast as soon as I connect the battery for about 20 seconds then stops).
sounds like a defect with the control board?
does anyone know how to contact Hubsan Service/Repairs?
Pea
(YouTube: Pea's Kites & Drones)
