h501s no bind
Posted: Mon Sep 03, 2018 4:28 pm
by yurik2013
Help! Help! Help! There is no connection with the console. When the power is constantly on, the crimson lights are lit. I checked all the connectors. The video board does not have a led light. What kind of malfunction?
Re: h501s no bind
Posted: Tue Sep 04, 2018 8:58 am
by magicmannst
https://www.youtube.com/watch?v=LH2mQfSvCY4
Re: h501s no bind
Posted: Tue Sep 04, 2018 3:52 pm
magicmannst wrote: ↑Tue Sep 04, 2018 8:58 am
Wat the video did not say is to
power on the transmitter while holding down the photo key to put it in the bind mode, then power on the quad and then the two should connect, you should then see FPV and prompts to Calibrate Compass 1
Re: h501s no bind
Posted: Fri Sep 07, 2018 3:33 am
by yurik2013
yurik2013 wrote: ↑Mon Sep 03, 2018 4:28 pm
https://youtu.be/HoeFim2HTcw
Re: h501s no bind
Posted: Fri Sep 07, 2018 8:11 am
yurik2013 wrote: ↑Fri Sep 07, 2018 3:33 am
How close do you have the transmitter to the drone? make sure they are touching, power on transmiiter with photo key pressed and then the done. I know the 501SS has a red led but not sure about 501S.
If your video board is not labled H501A Cam Board it is not a 501SS but an older model.
Re: h501s no bind
Posted: Fri Sep 07, 2018 12:44 pm
by yurik2013
model h501s
