h501s no bind
yurik2013
h501s no bind
Post by yurik2013 » Mon Sep 03, 2018 4:28 pm
Help! Help! Help! There is no connection with the console. When the power is constantly on, the crimson lights are lit. I checked all the connectors. The video board does not have a led light. What kind of malfunction?
magicmannst
Re: h501s no bind
Post by magicmannst » Tue Sep 04, 2018 8:58 am
https://www.youtube.com/watch?v=LH2mQfSvCY4
justjarhead
Re: h501s no bind
Post by justjarhead » Tue Sep 04, 2018 3:52 pm
Wat the video did not say is to power on the transmitter while holding down the photo key to put it in the bind mode, then power on the quad and then the two should connect, you should then see FPV and prompts to Calibrate Compass 1
yurik2013
Re: h501s no bind
Post by yurik2013 » Fri Sep 07, 2018 3:33 am
https://youtu.be/HoeFim2HTcw
justjarhead
Re: h501s no bind
Post by justjarhead » Fri Sep 07, 2018 8:11 am
How close do you have the transmitter to the drone? make sure they are touching, power on transmiiter with photo key pressed and then the done. I know the 501SS has a red led but not sure about 501S.
If your video board is not labled H501A Cam Board it is not a 501SS but an older model.
yurik2013
Re: h501s no bind
Post by yurik2013 » Fri Sep 07, 2018 12:44 pm
model h501s
