Month ago I have bought new Hubsan 501s Advanced, first flight was without problem. Today I turned on Hubsan, I took off, flew for around 1 minute, after that reciver started to beep, that GPS signal lost, it changed few times, it worked for few secconds, after that GPS signal was lost - 0 satellites, and few seconds after 11 satelites. Also when hubsan is on the ground and I touch and cover top of drone by hand, GPS signal is lost. What could be the problem? How to fix that?
Thank you
Petr
Re: Hubsan 501s Advanced
This is normal. There is a cell battery in the %01 that only charges when in use and will hold satellite lock longer. Keep next few flights short distances.
Putting hand over Transmitter or 501 blocks the GPS. DOn't worry about that. The important thing is having quad and transmitter turned on to charge the cell battery.
