501s controller
SteveNye
501s controller
Post by SteveNye » Sat May 22, 2021 6:56 pm
hi there
i am the proud owner of a 501s
had not used for a mth or so and when igot it out
Controller does not come on at all
drone fires up as usual
but controller dead
replaced mbatteries etc to no avail
can you please advise with any help
kind regards
steve
nyesview@gmail.com
1522624988604g1
Re: 501s controller
Post by 1522624988604g1 » Mon Aug 09, 2021 3:49 am
You could check the hubsan customer service and see what happens in a month or so? If you don't want to do that you may want to unscrew the 4 screws in the back corners and gently take it apart and check your power from the battery, but It could just be a solder point?
1522624988604g1
Re: 501s controller
