hi there
i am the proud owner of a 501s
had not used for a mth or so and when igot it out
Controller does not come on at all
drone fires up as usual
but controller dead
replaced mbatteries etc to no avail
can you please advise with any help
kind regards
steve
nyesview@gmail.com
501s controller
Re: 501s controller
You could check the hubsan customer service and see what happens in a month or so? If you don't want to do that you may want to unscrew the 4 screws in the back corners and gently take it apart and check your power from the battery, but It could just be a solder point?
Re: 501s controller
