error gimbal zino pro plus
me_a5852ZwStf
Post by me_a5852ZwStf » Fri Mar 26, 2021 5:19 pm
tras solo dos vuelos y sin ningun tipo de percance, es decir los dos vuelos perfectos, al encender de nuevo el drone me sale un error del gimbal.
el error 0x2000 angulo sensor del gimbal anormal. y no tengo forma de solucionarlo. le he instalado de nuevo la ultima version tanto del gimbal, como del firmware del drone y todo sigue igual el gimbal sigue sin moverse y me pone error de sistema, alguien sabe o me puede dar una solucion , solo llevo con el drone 10 dias gracias.
me_e3e9bHr6o5
Re: error gimbal zino pro plus
Post by me_e3e9bHr6o5 » Thu Apr 01, 2021 11:35 am
Yeah, mine did it too. Mine is only like 8 days old. After three flights and video recording. Went home to look at videos while the battery was charging. Put the battery back in and gimbal is dead, not a single noise or movement. Did all the updates, remove battery and put it back in...cant even do the gimbal calibration on the app, it gives me 'request timeout' with the 'The gimbal angle sensor is abnormal'. Not very happy.
me_91794oy4bi
Post by me_91794oy4bi » Sat Apr 03, 2021 3:58 pm
Did you have any solution for the problem?
me_43261WRm6a
Post by me_43261WRm6a » Sat Apr 24, 2021 9:30 pm
My camera came off in mid flight.. during a very important flight.. that God i had my DJI backup.
Think i may have to go back to Dji. Sorry
me_6da5fF5lBp
Post by me_6da5fF5lBp » Sat May 22, 2021 12:05 am
Muy buenas: Cambia los dos cables a la cámara del gimbal y calibra la cámara con una pieza especial que hay parecida a el protector que trae el Zino y así se puede solucionar. Todo esto te costara unos 10 ó 15 euros. ;)
KRLOS
Post by KRLOS » Tue Jun 18, 2024 2:54 pm
has encontrado solución?
