H216A can’t be calibrated or used.
me_9a1b9UDtL7
Post by me_9a1b9UDtL7 » Sat Jan 05, 2019 5:20 pm
I have the brand new Hubsan H216A which lets me connect the drone with the WiFi. I have to put in the password and it does secsefully connect but, the App says the app isn’t connected. In other words I can’t use the drone. It even lets me connect to the remote control and you can see that it is connected to the phone but all that doesn’t matter if you can’t use the drone ! Please fix it or find a quick solution.
me_90bcbmiVlP
Re: H216A can’t be calibrated or used.
Post by me_90bcbmiVlP » Sat Jan 05, 2019 11:35 pm
I had a problem with connecting and finally I uninstalled, then reinstalled the app. It connected fine after that. Maybe give that a try?
me_9a1b9UDtL7
Post by me_9a1b9UDtL7 » Mon Jan 07, 2019 2:04 pm
Thank you for taking your time and reading my problem, the solution is very easy to fix. The drone always needs some GPS signal or it won’t calibrate !
