Gimbal error
Gimbal error
I have a red icon that pops up saying gimbal error what do I do
Re: Gimbal error
Are you getting an error code? A lot of the time the gimble cable is loose, take and look behind the gimble at the top easily pinch with one finger on one side and thumb on the other. Then also look on either side of gimble at the top where it’s connected lightly press those connectors DONT PRESS TO HARD. If this don’t work you may need to replace the gimble cable... but this normally fixed the issue. Good luck and happy flying
