H502e Desire "toy" transmitter will not enter calibration
Hi, the calibration procedure for this transmitter for the 502e: both sticks to the top left in mode two when turning on, is not activating the process, it just turns on. Any help? I know this is an old quad but it flies great with my fpv transmitter but I like the small tx. Thank you!
Re: H502e Desire "toy" transmitter will not enter calibration
Solved.
Traced the problem of this H502e to a bad potentiometer on the left joystick on the "toy" controller.
Removed, cleaned and adjusted the wiper on the pot and reassembled.
All calibrations had to be redone.
Joysticks, then rebind because it loses the binding, then re calibrate the compass, then turn tx on and off.
It now works again as it should.
Lovely bird!
Lovely bird!
